Good point, I just replaced m6 with m0 in the post processor and it works perfectly.
--- In DynoMotion@yahoogroups.com, "himykabibble" wrote:
> There is absolutely no need to write any C code just to do a toolchange. Turn off the spindle and coolant in the G-code. If you need to do a manual toolchange, then put an M00 in the G-code, followed by an M6 Tn, then turn spindle and coolant back on.
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com, "ryant61175" wrote:
> > Hi,
> > What is the easiest way to stop the spindle and wait for a tool to be changed?
> > Can I just copy the MDI.cpp example and run m05 m00?
> > Will I be able to jog while the program is paused?
> > Thanks,
> > Ryan
